Do you have to change the front spindles when doing the 5 lug conversion?
I am going to put the 5 lug drum conversion in the rear first, then upgrade to disc later on, will I be able to use the same axles? Does anyone sell just the rear end kit? I found one at summit but it is 4 lug. Could I just buy that and some 5 lug rotors? What master cylinder do you fellas recommend? I know about the 2 thousand dollar kit that does everything, but after you add the price of wheels and tires its too pricey for me to get all at once. So I want to get the front kit from summit: http://store.summitracing.com/default.asp?target=partdetail.asp&part=FMS-M-1102-C&FROM=MG and the rear kit with 5 lug drums: http://store.summitracing.com/default.asp?target=partdetail.asp&part=FMS-M-1126-A&FROM=MG so I can get some new wheels/tires and then upgrade the rear to this: http://store.summitracing.com/default.asp?target=partdetail.asp&part=SSB-A112-1&FROM=MG hopefully with 5 lug rotors. Then eventually I will upgrade the fronts to Willwood or Baer (will i have to get different spindles then?). What do you guys think? Remember this is an ongoing project, and I am trying to keep it on the road as much as possible....this is just a battle plan. Is their any OTHER ways to accomplish this?
