5 Lug Rotors
junkyardjeff
28
Thinking about converting a 84 fox body LTD wagon to 5 lug and Autozone has a 5 lug rotor listed,it is physically a little larger so will it just go on or are there 5 lug only spindles.
I believe you have the 10" rotors. Most of the 5-lug conversion rotors are 10.9" and fit the 87+ v8 mustang spindles.
I believe mid 80's 4 cyl rangers had 10" 5-lug rotors and would be a direct swap onto your current spindles.
Edit; 1984-1990 2WD rangers had the 10" 5-lug rotors. Unsure if you will need to change out bearings
