5 lug??
  • Thread starter Thread starter doublenotch
  • Start date Start date May 14, 2006
doublenotch
Florida
May 14, 2006
  • May 14, 2006
Hello, I'm new to this site and new to my mustang. I have a 91 notch and would like to convert it to five lug bolt pattern. What rotors do I use and what axles and drums. If my memory serves correctly I can get lincoln mark vII rotors and two driverside ford ranger axles?? I'm not sure. Thanks in advance.:SNSign:
RBRANDX
110
Myrtle Beach, SC
May 14, 2006
  • May 14, 2006
Do a search on the topic...there are at least a thousand answers avalible!
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 14, 2006
  • May 14, 2006
cheapest front rotos would be a SVO rotor which was a 5 bolt pattern. also i believe if you get the caliper from the svo it is a larger one for more braking. just a idea. as for rear axles i would get a moroso or starnge engineering axle so that it is upgraded and no worries of twisting one out.
T
tddpop
26
Salt Lake City, Utah
May 14, 2006
  • May 14, 2006
Here is a site with tons of info on brake upgrades for fox bodies.
http://www.svo73mm.cjb.net/
Good luck!
T
tddpop
26
May 14, 2006
  • May 14, 2006
Here is another site with info.
http://www.mustangmotorsport.com/sn95conversion.html
doublenotch
Florida
May 14, 2006
  • May 14, 2006
Thanks fellas
Mustang5L5
Mod Dude
Feb 18, 2001
43,375
18,122
224
Massachusetts
May 14, 2006
  • May 14, 2006
another site
www.sn95brakes.com
keep in mind not all wheels will fit the Mark 7 rotors
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
