5-Speed Transmission
foxmustangman
196
Idaho
Okay, so it turns out that I burnt out my transmission possibly causd by me intalling my shift kit (i suggest NOT doing that one). :(
The cost to fix it is roughly 1600 but could be anywhere from 1200 to 2500. :eek:
So i figured "Screw automatics...get a 5-speed!" I can get a manual transmission for roughly the same price and have 2 times as much fun. (then none of my friends can drive my car either:nice: )...
So if i switch out my automatic, what will i have to get to put in a 5-speed?
Transmission, belhousing, and flywheel are a given...
Also, i have this crazy idea...can you put a torque converter in a manual transmission instead of a clutch, i mean, it makes sense to me...anyone else???
:shrug:
no you can't put a torque converter in a 5 spd, why does that make sense? Also you are gonna need the pedal assembly and a clutch which I didn't see above, the inside console for the 5 spd, and the clutch cable. There is more I know, I just can't think of everything.
pedal assembly
the console boot and inner boot
the trans of course
bellhousing
clutch assembly
pilot bearing
throw out bearing
clutch cable
flywheel
a couple hours, a few cuss words, carton of cigaretts, lots of vault and then bam its done, then the moment you start it up powershift it everywhere you go, then go buy a tremec!!!
pedal assembly
the trans of course
bellhousing and clutch fork
clutch assembly
pilot bearing
throw out bearing
clutch cable
flywheel
clutch quadrant
shifter and knob
scatter shield
added a few things, but couldn't have said it better myself. the transmission swap is the easy part, it's putting in the clutch pedal assembly that is a b*tch when you have a full interior. just dedicate a weekend or a few days in a row to get it done. especially since it's your first time, take your time doing it. it's not that bad though, just time consuming. oh and make sure you have a clutch alignment tool (should come with clutch kit), it'll make stabbing the transmission 10000x easier.
How difficult is the pedal assembly swap? I think that would be the worst part, I am in the same boat and it looks like you have to be pretty "bendy" to get to it...
There not to bad. First i take the set out then drop the steering column. then its just four bolts think there 9/16 and a few plug in's then you have to work it out from under the dash.
And you will need a tran harness. car won't start unless you get a 5 speed one or jump the wires for the N saftey switch.
Ive never taken one out but I believe you coud get it out in about 1 1/2 hour if you decide to takle it. if you dont want to do that, ive always wanted to put the clutch on the shifter, I think that would be kewl, ill try to get a pic off of a motorcycle.
I have seen them on a motorcycle. But i would like to see that on a car. You would have to have one h**l of a grip to do it. So we know what you do in your spare time.
I just did the swap myself about a month ago...
i would suggest doing the pedals one weekend and then doing the trans the next... unless its a daily driver don't worry about it.
took me 5hrs to do the pedals ( breaks etc..) florida heat sucks... and it was a pain in the ass! but not hard at all to do...
then took me 12hrs to do the trans swap... this is coming from someone that has never taken a trans out of a car before... its really easy to do... just time comsuming!
i would suggest getting that AOD out of there... also make sure the trans is rebuilt or new one...
because i need to replace the used one i got... i got lied to and my 2nd gear sncyro is shot and 3rd gear whines!
