5000 rpm's without stepping on gas
DCjuggalo said:
anyone know what would cause 5000 rpms without hitting the gas, sometimes it will fall down to 1100 where its supposed to be, but it dont do that much thanks
1100 ?? Just noticed that.. do you have a huge cam in there? Is your throttle plate jacked way open to get it to idle higher? Normal idle should be like 600-700..
I would also clean out the IAB -- I've fought problems with those before that had similar symptoms. Sometimes they just don't clean out enough (or something else is wrong) and you have to replace them.
I second the IAB issues. Ever start your car without the iab? WOW!!!
Scares the begeezes outa you.
