.550 lift springs
asleep89stang
10
I have decided to run a TrickFlow stage 1 cam with my AFR 165cc heads, how close is safe when it comes to coil bind on the valve springs. I am running 1.7RR's and the lift should be in the rang of .529 intake and .540 exhaust, is this safe to run with the exhaust lift just .010 away from bind? I could step down to 1.6RR's but I have already bought the 1.7RR's.
You'll be fine. I think the springs actually have coil bind at around 1.10", which with a 1.80" installed height is a .700" lift. The .550" is just a recommendation on how high. I have my AFR papers, I can look it up.
what cam are you THINKING of running? i would definately upgrade your springs to a .600 lift for the $100 or so that they are. its better now, than changing them later down the road.
Thats the thing, I don't know what to run now, I was under the assumption that I had to run under .550, But your right I should change the springs to, any off the shelf cam recomendations? I am not trying for a custom cam, seems like alot of money.
OK, since you mentioned the Comp Cams, i used the Xe274 and had good results. that is a .555/.565 lift cam, so your springs are going to take a pounding.
Custom cams are very, very nice. yes, you will spending $100-150 more on one Vs. a Comp Cams camshaft, but its built for YOUR car.
as for springs, i would get some COmp Cams double or tripple coil that can handle an agressive cam and .600 lift.
