What's wrong? clutch, trans, or cable?
My trans started grinding going into 5th about a week ago. It does it almost every time. I have to pull everything out and see what's wrong. Just wanted some input first though. Here are some of the problems with the car. At first I just assumed it was the synchro. The rear main seal is leaking. The clutch is supposedly new, but I am sure oil on it has worn it. It lifts somewhat high and is pretty stiff. The clutch does not slip. However, to test it out I mashed it in 4th while driving up a hill a couple days ago. It didn't slip, but I smelled something burning after that. I was also wondering if the cable could be bad. When I first got the car, 3rd was grinding a couple times but went away. Now it is just fifth.
My question is, where could my problem be: transmission, cable, or clutch?
