6 Disk CD Player
  • Thread starter Thread starter Strype
  • Start date Start date Oct 9, 2007
1 of 2 Next Last
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 9, 2007
  • Oct 9, 2007
Anyone know how to get my 6 CD's outta the 01 GT. Factory player says CD ERROR
PS: I didn't think this fit as tech, but by all means if it does
Mossberg
ATL, Shawty
Oct 9, 2007
  • Oct 9, 2007
Ford just replaced mine with a new one when I had this problem. I received my CDs back about a week or two later from Ford.
If you can see the CD that is stuck through the dust door, you might be able to grab it with some thin needle nose pliers.
Just a FYI, never use CDs with stick-on labels. The Ford Visteon radios eat those for lunch.
lvmustanggt
721
Las Vegas
Oct 9, 2007
  • Oct 9, 2007
been 2 weeks with out cd , says cd error so cannot play, eject .
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Oct 9, 2007
  • Oct 9, 2007
You could probably disassemble it if you were highly motivated.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 9, 2007
  • Oct 9, 2007
DocG2828 said:
You could probably beat the snot out of it with a claw hammer if you were highly motivated.
85ragtop
BTW, I like dudes.
475
123
NC
Oct 9, 2007
  • Oct 9, 2007
Strype said:
I was going to say shoot it, but that will work.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 9, 2007
  • Oct 9, 2007
That's my problem too!!! We should petition Ford
^^^Always thinkin that one is
85ragtop
BTW, I like dudes.
475
123
NC
Oct 9, 2007
  • Oct 9, 2007
what I told you I was a redneck.
Saleen311
67
Hampton, Va
Oct 9, 2007
  • Oct 9, 2007
this is why i always put copys of my cds into car CD players
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
Oct 9, 2007
#10
  • Oct 9, 2007
  • #10
I thought I heard of guys using a credit card to stick in there and convince the cd player to spit them out. I've never tried it though. Does the in-dash use the DIN style clips? If so, I'd cut and bend a hanger to pop that sucker out.
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Oct 10, 2007
#11
  • Oct 10, 2007
  • #11
Mine did the same a few times here and there last year ,and started again a few months back,but more often,and also with other issues like not reading my cd for like 20 to 30 minutes,but i have since replaced it with an aftermarket deck.To get the cd's out,just grab an old cd,hit the eject button,the error code will come up,then just slide the old cd in a bit,and the cd in the player will come out.If you have all 6 slots filled,then you will have to do this 6 times.It's easy.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 10, 2007
#12
  • Oct 10, 2007
  • #12
If this works I will owe you one... Well "one" excluding anything remotely ghey but you know what I mean
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Oct 10, 2007
#13
  • Oct 10, 2007
  • #13
If that doesn't work.....you might need to cut the power to it to reset the unit.....but I'd be careful, not sure how the PATS likes you disconnecting the battery these days.
04fullitgt
I shower with poo
Nov 13, 2006
Crest Hill, Illinois
Oct 10, 2007
#14
  • Oct 10, 2007
  • #14
Strype said:
If this works I will owe you one... Well "one" as in anything ghey.
FIXT!
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 10, 2007
#15
  • Oct 10, 2007
  • #15
Okay I didn't try the cd trick cause I couldn't see a cd. Evidently it's stuck in between cd changes or something
04fullitgt said:
FIXT!
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Oct 10, 2007
#16
  • Oct 10, 2007
  • #16
Don't need to see the cd,just do what i stated in my post above,and all is well.Believe me,it works.I know,cause it did it to me.Just take an old cd,and put it in the slot without letting it go right after you hit the eject button,and pull it back out,then you should hear the stuck begin to eject like normal.
Damn,i wish we could travel threw the computer screen,i would do it for you.
It's way to eazzzzzy ,on a level of hard being 1 and easy being 10,it's a 10 for anyone.
lvmustanggt
721
Las Vegas
Oct 10, 2007
#17
  • Oct 10, 2007
  • #17
I just did the cd thing and didn't work. I put cd half way in , press eject and it say select cd and I did but not working for me
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Oct 10, 2007
#18
  • Oct 10, 2007
  • #18
Okey,lets make this 3 times a charm in FULL detail!
First hit the eject button.
Second choose your slot.
Third,when it gives the error code on the screen of the 6 cd player,slide an old cd into the opening without letting it go,then pull it out(if the stuck cd doesn't eject,then you didn't put the old cd in far enough).
Fourth,pull the old cd out,and the stuck cd will/should eject out.I know it works,i had to do it to 6 cd's that got stuck in my factory 6 cd player,that is where i made my descision and got an aftermarket player.
I reallyu wish i can come and help you guys...LOL!
lvmustanggt
721
Las Vegas
Oct 11, 2007
#19
  • Oct 11, 2007
  • #19
I just tried again as you said but it didn't work for me. This all started when i change my spark plaug. Negative battery out to change my spark plugs, plug back in and start my car but I remember that I forgot to plug my mass air so I shut my car and took negative battery out so I could set my computer . After that cd never worked and just gives me cd error. It used to make lot's of noise when you reset your computer with battery off but now it don't do *****
Tim2002GT
635
Tulsa, Oklahoma
Oct 11, 2007
#20
  • Oct 11, 2007
  • #20
+1 This always works for me.
1 of 2 Next Last
T
Need advice: 93 Cobra audio upgrade with no permanent modifications
  • THNX SVT
  • Feb 18, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2024
TIGGER
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
