My clutch went out last night......
I already ordered a centerforce dual friction clutch set but I decided to replace the flywheel too. I was just wandering if I had a 6 or and 8 bolt crank? Did ford only use certain ones for each year? I was told that only the 01 and up mustangs had a 6 bolt crank but I don't want to order the wrong one and be screwed. I have a 98 GT by the way.
) but my guess is that it might have been the aluminum flywheel that was responsible for the bit of slippage you experienced, not necessarily the KC clutch. They may be a lot lighter that the all steel units, but from what I've seen they don’t tend to have the holding power. They give up a little surface area on the friction surface in order to countersink the bolts to mount them to the flywheel. I've also heard of the aluminum flywheel having a tendancy to flex under higher RPM/temperatures in comparison to the steel unit, but I can't confirm or deny this. It seems to just be word of mouth at the track from a lot of the racers in various classes.
