6 speed
  • Thread starter Thread starter jozan
  • Start date Start date Jan 19, 2007
J
jozan
60
  • Jan 19, 2007
does anybody have six speed in a fox and will it fit in the same place as a five
N
niklid05
140
Kutztown PA 19530
Jan 19, 2007
  • Jan 19, 2007
yea there are a few people. Youll have to move the tranny crossmember and a bunch of other ****. Search for a member on here named caseywan.
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Jan 19, 2007
  • Jan 19, 2007
groverdill has one too.
91ghp5.0
42
Somewhere
Jan 20, 2007
  • Jan 20, 2007
D&D transmission makes a kit that will convert you to a T56 6 speed (same transmission used in 4th gen camaros and 03/04 cobras).
N
niklid05
140
Kutztown PA 19530
Jan 20, 2007
  • Jan 20, 2007
I think youre wrong, but I could be wrong.... But I believe the cobras had a .62 6th and the camaros had a .50
Adams91LX
689
12
29
Plano, TX
Jan 20, 2007
  • Jan 20, 2007
t56 is same as 03/04 cobra's and viper's i thought...
91ghp5.0
42
Somewhere
Jan 20, 2007
  • Jan 20, 2007
Oh I don't know if there is a difference in the ratios of the gears (specifically 6th in this case), but I was just saying that the T56 is a pretty broadly used 6 speed. F-bodies, 03/04 cobras, and vipers.
N
niklid05
140
Kutztown PA 19530
Jan 20, 2007
  • Jan 20, 2007
Oh I see what youre saying...yea they all use t-56's. They just have a few things differing from each other.
91ghp5.0
42
Somewhere
Jan 20, 2007
  • Jan 20, 2007
Exactly!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 21, 2007
#10
  • Jan 21, 2007
  • #10
Here's some clues...
1.) The driveshaft is shorter, the yoke is probably different
2.) The rear crossmemeber and transmission mount is different. The T56 mount needs to be welded in aft of the stock mount.
3.) The bellhousing is different, no bolt and go junkyard part will fit. McLeod ( http://www.mcleodind.com/index.html ) makes an adapter to mate an GM F body T56 to a 5.0 engine. It will takes some digging at their site to find all the parts. Call them if you are interested.
6.) You will need some sort of speedo adapter to mate the speedo cable to the trans. Some T56 are electronic speedo.
7.) The clutch disc is a 26 spline 10.5" chevy unit for most of the T56's.
The D&D kit is probably the simplest way to make it happen. See http://www.ddperformance.com for more info. Last time I heard it was like $2600 for the kit that had everything you needed. MM&FF magazine did a swap using one of ther kits. Check out the back issues for details.
MAC'n89Blckstng
1,012
NJ
Jan 21, 2007
#11
  • Jan 21, 2007
  • #11
my friend put a t-56 conversion kit in his car and was just like putting in a T-5, just with different parts. it was something around like 2200 bucks. I'd personally rather have a TKO600.
larrendeuce
649
Southern NJ
Jan 21, 2007
#12
  • Jan 21, 2007
  • #12
MM&FF did the swap in one of their project cars, Jan 07 issue I think. The D&D crossmember mounts in the stock location, but it has more of a \____/ shape to accomodate the longer T-56 with the farther rearward mounting points. No modifications needed, can still swap back to a T-5 if needed.
J
jozan
60
#13
  • Jan 23, 2007
  • #13
thanks guys
C
caseywan
157
Chicago, IL
Jan 24, 2007
#14
  • Jan 24, 2007
  • #14
Check out this thread, I posted a ton of info on the swap in it.
http://forums.stangnet.com/showthread.php?t=651757&highlight=T56
88gt
794
Drillers cabin
Jan 24, 2007
#15
  • Jan 24, 2007
  • #15
It's the same....only different.....
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
D
What's it Worth? 76 Cobra 2
  • dulcimerbob
  • Sep 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 12, 2026
dulcimerbob
D
Enclosed car hauler
  • Sparky714
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 21, 2026
revhead347
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
K
Engine rebuild in connecticut
  • Kngtmare
  • Aug 30, 2026
Potomus Pete
