60lb Injectors Installed - Running Rich
Treachery
148
At the recommendation of my dynotuner, I upgraded my injectors from 42lbs to 60lbs.
I am now running rich... maybe too rich.
Between now and my next dynotune, i need to use my 93 Mustang a few times.
Should i compensate running rich by backing off the fuel pressure (currently at 39 psi) a little?
Thanks.
Unless your combo has changed from your sig, my advice, reinstall the 42's and find a new tuner.
You don't need 60's until you are well past the blocks limit.
I know for a fact 42's will handle 520rwhp.
