64.5 headlights go off and on
sbleifus
25
Hot Springs, AR
I have a 64.5 coupe with generator. I've completely rewired the car. When I turn the headlights on, they stay on for about a minute and then go off. If I turn the switch off and then back on they come back on for about a minute. Any ideas? Also, all my parking lights work when I pull the switch to parking lights, but when I pull the switch all the way out the front parking lights go out. Is this the way they operate?
Thanks in advance,
Steve
The Light switch has a built-in circuit breaker. It's likely getting weak. When you turn it off it is resetting.
You need a new switch. Did you replace the headlamps with halogen? They draw a little more power.
The park lamps are designed that way. it's normal.
tim is correct. my headlight switch was the problem. and then a little while after i fixed it, it happened again but they would constantly flash. ended up being my alternator dying because they couldnt power my halogen headlights and stereo. just another thought
