65 EFI Pedal Setup
  • Thread starter Thread starter development1
  • Start date Start date Sep 15, 2006
D
development1
25
Burnaby, BC, Canada
Sep 15, 2006
  • Sep 15, 2006
Hey,
I had another question in regards to a 65 mustang EFI conversion. I have been doing some digging around and I decided to run a 69 mustang gas pedal. My question to you is what throttle cable do you run? On some forums I was told to cut off the tip off the tip of the pedal and replace with one from a fox guy on the phone said to stick with the 1969 pedal however, use Lokar throttle cables. So I got on the phone with Lokar and they said to use part numbers TC1000HT and TCB40EFI. Does this sound familar to anyone? Also for the fuel pump I have decided to stick with the stock gas tank, however, which in line fuel pump do you guys recommend? I was told the BBK 255lph would be good, but I don't know how quiet that model is?
Thanks
G
garycroix
39
GA, wish it was NC
Sep 15, 2006
  • Sep 15, 2006
You can use a stock Ford throttle cable.
66HertzClone
428
Central New Jersey
Sep 16, 2006
  • Sep 16, 2006
Can't help you with the cable question, the EFI I used is not at all like the conversion you are doing.
I did use this fuel pump, Walbro GSL392, it is quiet, small enough to fit where I wanted it to go, and wasn't very much money. See here for the pump, http://www.autoperformanceengineering.com/ There are photos of the pump mounted on my car on my CarDomain pages. I used a fuel filter and the filter bracket from a Windstar. I ran a new plastic supply line up along the right side frame rail, I cut the original steel line off just before it bends down to connect at the fuel tank. I used a compression union and another piece of steel line with a fitting and connected this to the drain plug on the tank. This serves as the return line. I mounted my regulator just below the master cylinder and routed the return down to what has become my return line.
red65
411
Ann Arbor, MI
Sep 16, 2006
  • Sep 16, 2006
A second positive vote for the Walbro GSL392. I bought mine as a Holley 12-920, but it's the same pump (even says Walbro on the side). It's quiet and, so far, more reliable than the other pumps I've tried (stay away from the T-rex pumps, based on my experience). I mounted mine just in front of the fuel tank, and incorporated a surge tank as well (but that's a whole 'nother story).
I used a Windsor Fox adapter, Fox mustang pedal and a stock Ford EFI cable, fwiw, and they work fine.
gonzothegreat
421
London (uk)
Sep 16, 2006
  • Sep 16, 2006
check my setup:
http://www.thefroginator.co.uk/index.php?folder=/022-Pictures/EFI/pictures/day8/
G
garycroix
39
GA, wish it was NC
Sep 16, 2006
  • Sep 16, 2006
Hey Gonzo, where did you get that gas pedal? I really like it.
Gary in GA
T
truck90278
382
Redondo Beach, CA
Sep 16, 2006
  • Sep 16, 2006
gonzothegreat said:
check my setup:
who's shock tower braces are you using?
D
development1
25
Burnaby, BC, Canada
Sep 17, 2006
  • Sep 17, 2006
Yeah BBK called me back, and the tech on the phone said no to use the BBk pump. At least he was honest. What do you guys think of the MSD PN 2225 in line fuel pump, it's rated of 43 gph at 40 psi? Any past experiences?
D
development1
25
Burnaby, BC, Canada
Sep 17, 2006
  • Sep 17, 2006
Hey what do you guys think of the MSD PN 2225 it's rated at 43gph 40psi
gonzothegreat
421
London (uk)
Sep 17, 2006
#10
  • Sep 17, 2006
  • #10
They are from TCP
gonzothegreat
421
London (uk)
Sep 17, 2006
#11
  • Sep 17, 2006
  • #11
Gary in GA
it's the Lokar kit for early mustangs
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Car popping car starts up but wants to die if I don’t hold pedal down
  • Creomod
  • Mar 25, 2024
3K
Fox 5.0 Mustang Tech Jun 16, 2025
AeroCoupe
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
M
  • mnky99
  • Sep 5, 2025
mnky99
M
