- Jan 17, 2010
- 3
- 0
- 0
I am helping a friend on a 66 Mustang. I do not know what the specs are on the motor. The previous owner bought it from a Ford Dealer Mechanic. It sounds pretty good so I would have to say it is not a stock cam. It has a Edelbrock performer manifold and a Holley 600. Trans is a C4. We went to put a Electronic distributor in it. I would get it all timed @ 08 deg adv then hook the vacuum advance line up and nail the gas and the idel would take off and the timing would be way advanced and take a couple minuites to come down. The distributor was one of the e-bay Procomp's. I called procomp and they said there was an adjustment inside of the cannister and take an allen key. They could not tell me what size allen key and I could not get it to adjust. My friend went and bought a stock rebuilt distributor. I installed and the same thing. With the vacuum advance line off of it and plugged I have it timed @ 8 deg adv. I nail the carb and only get a couple deg advancement and runs great. I plug the vacuum line in and do the same thing and the iddle goes way up and the timing goes off the chart. My 8 deg timing mark is setting at almost 12 oclock on the motor when doing this. I unplug the vacuum and the timing goes back and the idle is fine. Is there a vacuum reducer that should go in line to reduce the vacuum to the advance cannister? Any help with this would be appriciated.
Thanks,
Bret
Thanks,
Bret
