I have a friend who has a 9" out of a 66 bronco . He said he thought they were about the same width . The bronco rear is 58" from flange to flange an the 66 stang is about 57.25 flange to flange .Now thats not to bad ,But i have a set of 17" X8 TTIIs with 4.75" backspacing that are still in the box . Will the rims still fit without cutting down the bronco rearend . If this rear has to be cut down is it true that the axles cannot be re-splined. What do you think ? I am told that it is a posi but am unaware what gearing is in it.It may still be worth buying .
