66 mustang overheating??
  • Thread starter Thread starter micjoe
  • Start date Start date Nov 28, 2006
M
micjoe
34
Connecticut
Nov 28, 2006
  • Nov 28, 2006
my 66 mustang V6 just started to overheat..I will travel about 10 minutes and watch my temp gauge go all the way to hot. I am told it may be the following:
Theromostat stuck open
Raditor Cap
Radiator
Water pump
I dont know too much about cars in the regard to figure out the issue. This is an experienced board so i am asking for help.
Should i just but a new raditor cap see if that fixes it?
I noticed the raditor has cracks on it and needs to be replaced. The overflow tube leaks raditor fluid regularly. It will smoke heavily after 10-20 minutes of driving.
Any help ?
J
John Z
581
Morgantown WV
Nov 28, 2006
  • Nov 28, 2006
First things first
You do not have a V6 engine. Look at your engine, see how all the spark plug wires are in one line? You have an inline or I6 engine.
Overheating is a common problem and a search of this site will provide a wealth of information.
However, to get you started:
A thermostat stuck open would not cause your problem as water could flow so you would have a problem with the engine not coming up to temperature fast enough. However, most thermostats will break in the closed position, blocking water flow to the engine. My first step would be to replace the thermostat, cheap part and easy to replace. Just be careful to put it in with the correct orientation, the flow direction should be indicated on your new thermostat.
One function of the radiator cap is to allow the engine to build up pressure which increases the boiling point of the antifreeze/water. A bad radiator cap allows release of pressure and you sould see steam from the radiator cap. This does not sound like your problem, but replacing the cap as a preventive maintenance measure is a reasonable idea.
What do you mean the radiator is cracked? If you add water does it flow out these cracks???? Seems like you would have mentioned this???
Since these cars did not have overflow tanks, the proper procedure is to fill the radiator to about 1" below the neck, just cover the tubes. If you fill the radiator to the top the excess will flow out the tube when the engine heats up. This is normal for an overfilled radiator.
The smoke you mentioned is a very bad thing, you could have already caused serious damage to the engine.
68 Coop
104
Mesquite, NV
Nov 28, 2006
  • Nov 28, 2006
Any help ?
Do you mean the engine smokes, or the radiator spews steam out somewhere. Check your lower hose and see if it is really soft to squeeze together. If so, toss it and get one with a spring in it, the old one is probably collapsing in on itself after the engine starts to pull the coolant through it.
M
micjoe
34
Connecticut
Nov 29, 2006
  • Nov 29, 2006
No the engine does not smoke. it smokes (steams) from the raditor and when i slowly take cap off, smoke (steams) comes from the radiator...
It only leaks after i have drove the vehicle....i guess i will look at finding out how to replace the theromstat its to my knowledge that would cost 8 bucks and hosing is like 22 bucks.
i will look for a manually hopefully and replace it..
68 Coop
104
Mesquite, NV
Nov 29, 2006
  • Nov 29, 2006
You don't need to replace the housing, just the t-stat. Did you check the bottom hose? It could be the problem. As far as changing the t-stat, just put the big round part (sensor) down (inside the block), and the bell looking part (top) should be exposed until you remout the housing. Buy a Failsafe t-stat, so even if it does go bad, it remains open. It's 2 bolts, just make sure you get a new gasket for the house, and it's a matter of tightening it back down. Don't go all muscle man on it, you will crack the housing, and then you WILL need to get a new one.
M
micjoe
34
Connecticut
Nov 29, 2006
  • Nov 29, 2006
Where is the thermostat located on the engine block? near raditor?
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Nov 30, 2006
  • Nov 30, 2006
Have we established if this is a V8 or a 6 banger? Anyways, these instructions are generic enough to work for either:
The thermostat is located on the front of the motor, under a metal housing. Basically follow your upper radiator hose back until you see where it is clamped on the front of the engine. The thermostat is located inside that metal housing that the hose is clamped to. You must remove the hose and the 2 bolts that hold the housing to the motor in order to replace the thermostat.
You will also need a new gasket--they are often sold separately and not included with the thermostat.
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
