66 shelby side scoops,rivet ,bond or both?
'69Mach1
45
Northern N.J.
I am about to install the '66 Shelby side scoop's on my convertible,originally they were riveted in place ,now I see that the Eleanor's fiberglass is bonded in place with two part panel adhesive ,is it O.K. to just bond them in place?having never worked with this stuff before ,I thought I'd ask ,also ,can you bond the fiberglass directly to edp coating?or does the stuff need bare steel to make a strong bite?plus on the scoops, it only gives you an area 1/2" wide to work with ,if I use two part only ,will it be enough area?sorry for so many question's.
I know what you mean about the narrow lip. There's not much there to rivet to. Mine are glued on with the panel adhesive you are talking about. I don't remember if they were glued to bare metal or over the primer. By gluing them on, we were able to mold them into the body. Instead of having the small gap between the scoop and body, mine have a very tight radius countour to the body. The adhesive if very strong. Once it's set, you'd have to break them off and grind off the excess if you ever wanted to remove them.
Cobain03 said:
any pics of them molded into the body?
Well, these pictures are kind of hard to tell detail considering the color of the car, but it might give you an idea.
