66 w/T5 vibration (bad)
427sohc
Germany
Would appreciate any suggestion on where to look to fix the following problem:
Slight vibration at about 40mph. this vibration can be felt just about anywhere in the car. Severe (really) vibration starting at 80-85mph. It is independent of engine rpm as the vibration continues if I take it out of gear at this speed. This vibration seems to be less noticeable in the steering wheel compared to anywhere else in the car. The shifter is really bad. I am afraid to take it up to higher speeds as it feels like the car wants to shake apart.
I have so far balanced the drive shaft and the wheels. Also tried a second set of new wheels. No difference. The guy balancing the shaft said he saw nothing wrong with the U-joints. Also can't feel any play where the drive shaft enters the tail housing.
Setup: 66 hardtop with a strong 289 (carb, intake, heads, cam, headers, etc.). T5 tranny installed. I am told the rear end is a 4.11 setup. Don't know this for sure as I just bought the car.
Suggestions?
Try putting the rear axle on jackstands and running the car in gear. Have someone give it some throttle and run it up through the gears while you watch the drivetrain for obvious ocillation or shaking.
The problem might not be obvious without "loading" the drivetrain, but it's worth a shot.
Might be a bad tail housing busing in the trans. Or one of the u-joints. But if you had the drive shaft balanced the shop probably checked the joints. Also, is the joint centered in the rear end? Sounds like the trans if the shifter is that bad though.
I had a vibe issue when I had my C4 rebuilt on my former 64.5 . Turns out that the driveshaft was not exactly centered in the pinion flange. Simply loosened the u-bolts, lines it the center and retightened the bolt. Solved my vibes.
Ronstang said:
It could be a drivetrain angle problem. When you use a commercial crossmember to install a T-5 you end up at about 6 degrees and stock is 3 degrees.
I agree that it COULD be a drivetrain angle issue. (and should be checked)
I disagree that a commercial crossmember WILL give you a 6* angle with a T5. My Ron Morris X-member came in at 3.5*. I think the 6* is what some swappers were reporting with the Darkhorse TREMEC x-member. ;)
Thanks for the quick replies.... :hail2:
Loup-garou: I admit I am a little hesitant to do that. Sounds a little dangerous to me.
Mr_siv: Tried that. Pretty sure it's not the wheels
STSFCTN67: Do you mean adding height between the crossmember and the tranny? In other words, raising the tail housing? Do you recall how much you raised it?
VictorII: How do I check for a bad tail housing bushing?
one2gamble, Ronstang, BobV, Glen's 1965 5.0: In one way or another you all talk about the drive train angle. Sorry for my ignorance, but what exactly is the drive train angle? And, like one2gamble, I would like to learn how to measue it.
mustangprodude: I will check that, thanks.
To summarize:
1. I try to check on whether the u-joint is centered at the pinion
2. Should I try to raise the tranny on the crossmember?
3. Drivetrain: I would appreciate more details from you guys on what exactly it is I should be looking for.
Thanks again. Help like this is not easy to come by here in Germany :confused:
My car suffered the exact same problem, I was ready to pull the engine and tell the guy who balanced it to stick it up his a$$ when I found the transmission was touching the tunnel in the shifter area. Make 100% sure there is no contact anywhere.. After some trimming on the hole in the tunnel the vibration is no more..
The way I do it is to disconnect the rear of the shaft and then sort of wiggle the yoke while it is in the tailshaft. I don't know the exact spec. but it should be free, however not too free. If it wobbles all over the place, it is likely bad. Hope this helps.......
It is not the driveshaft angle it is the fact that when you tightened the C4 tranny mount to the new crossmember the bolt bottoms out without torquing the two parts together enough. Add about two regular hardware washers and let me know if that works.
STSFCTN67: Do you mean adding height between the crossmember and the tranny? YES undefinedIn other words, raising the tail housing? Do you recall how much you raised it?
To summarize:
