66 water pump
  • Thread starter Thread starter stang66convt
  • Start date Start date Nov 21, 2006
stang66convt
29
  • Nov 21, 2006
have the cast iron water pump with backing plate over impeller
question is can i just replacw with aluminum water pump with no backing plate
302 coupe
1,952
Macon, Ga.
Nov 21, 2006
  • Nov 21, 2006
you need to use the backing plate to keep the correct impeller to wall clearance. If the clearance isn't right, the pump doesn't function properly, it just makes a bunch of bubbles and turbulence instead of pumping water.
D
D.Hearne
11,730
south louisiana
Nov 21, 2006
  • Nov 21, 2006
Also depends on what timing cover you have. There are at least two different covers, one's deeper behind the pump, that one requires the backing plate.
stang66convt
29
  • Nov 21, 2006
thanks for the info that helps a lot
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
4K
Classic Mustang Specific Tech 43 minutes ago
GOvert
G
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
water pump pulley stock diameter
  • KAWMAN2
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
General karthief
