'66FB 289 - Starting Issues
  • Thread starter Thread starter hivewax
  • Start date Start date Jul 3, 2007
hivewax
233
Miami, FL
Jul 3, 2007
  • Jul 3, 2007
i just had this mini starter installed in May 2006... a Denso Type CHM Brand with a 4.0:1 gear-reduction ratio, 1.9hp, and 222 ft.lbs. cranking power. the mechanic selected this brand.
i turn the ignition and all i hear is a single click from the starter or maybe something else (solenoid??). i thought i had a dead battery, so i replaced it with a new battery. i heard the same single click. is the starter gone? is this usually how long they last?
hivewax
233
Miami, FL
Jul 3, 2007
  • Jul 3, 2007
forgot to mention, the car is my daily driver.
Blu-Steel
92
Waynesville, MO
Jul 3, 2007
  • Jul 3, 2007
Check the starter solinoid. Often times it goes bad and won't pass a current. You can jump the post with a wire or remote starter(be sure the ingnition key is in the On position. If it stars that's the problem. If not, either that Starter is bad or your battery is too low.
hivewax
233
Miami, FL
Jul 3, 2007
  • Jul 3, 2007
thanks for the help.
iskwezm
4,159
20
79
Rowland Heights,California
Jul 3, 2007
  • Jul 3, 2007
see if the cable to the starter is getting hot, if it does the stater probably has high resistance in the windings, if it doesnt, check the solenoid.
hivewax
233
Miami, FL
Jul 5, 2007
  • Jul 5, 2007
ok, i changed the solenoid and the same problem... one click. so, i'm going to take out the starter and get it tested.
questions: i've changed the battery cables, which are now 2/O. the old cables had black as positive. can a thicker cable draw too much power to the starter and work/blow the motor of the starter? is this the high resistance that Isky is talking about?
65driver289
40
Salisbury, Maryland
Jul 5, 2007
  • Jul 5, 2007
you could always check the starter yourself with some jumper cables. just tap the hot conection and the starter should bump over. I would do this with the starter out of the car ofcorse.
hivewax
233
Miami, FL
Jul 6, 2007
  • Jul 6, 2007
starter is bad. got it tested... turned like a snail. so, i'll get it rebuilt somewhere. anyone have pointers/comments. thanks.
EDIT: is it true, hi-torque mini starters cannot be rebuilt?!
hivewax
233
Miami, FL
Jul 7, 2007
  • Jul 7, 2007
got it rebuit for $90... car starts up. woohoo!
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
T
Electrical 1990 Vert starting/Solenoid issues
  • Tom77
  • Apr 18, 2025
Fox 5.0 Mustang Tech Apr 18, 2025
85GTStangGuy
P
Seeking Help - Hot Start Issue
  • Pony named Pearl
  • Aug 24, 2024
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 14, 2024
Pony named Pearl
P
Another no start thread.. pls help
  • Sarah84eyedfox
  • Apr 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
AeroCoupe
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
