67 and 68 dash
  • Thread starter Thread starter kidtaurus
  • Start date Start date Feb 22, 2004
kidtaurus
221
Athens, Ga.
Feb 22, 2004
  • Feb 22, 2004
I recently bought aluminum trim that I assume goes on goes on top of the camera case finish trim for my 68. The one I bought was for a 67 under the impression that the only difference between 67 and 68 was the front side markers. When I went to test the fit before I glue it does not fit properly. So are the dashes slightly different? Am I installing these things correctly?
hhead
280
so cal
Feb 22, 2004
  • Feb 22, 2004
the dash bezels ARE different. the turn signal indicators, the high beam indicator just off the top.
kidtaurus
221
Athens, Ga.
Feb 22, 2004
  • Feb 22, 2004
I got the passenger side stuff. Is that side different?
67efivert
348
lincolnton nc
Feb 22, 2004
  • Feb 22, 2004
only the gague cluster is diff and only the bezel at that just get a 67 bezel and all problems will go away
kidtaurus
221
Athens, Ga.
Feb 22, 2004
  • Feb 22, 2004
thanks for the replies I guess I will have to get the camera case bezel from a 67 then put my aluminum trim on it.
Edbert
3,548
32
109
Austin TX
Feb 23, 2004
  • Feb 23, 2004
The drivers side IS different on the two (standard and deluxe) as well as the passenger side. Only the three small (both ends and middle) should work without modification. As has already been posted the gauge pod has different plastic aroung the turn signals, and the glove box panel will need to have the mustang eblem ground flat with a dremel.
Did you get the kit that has an aluminum backing plate? If so you should get the right plastic bezels since there are tabs that will need to penetrate through the bezel and be bent fplat from the back. If you have the sick-on kind you may be okay without it but it may not sit flush either.
Hope that makes sense to you...
kidtaurus
221
Athens, Ga.
Feb 23, 2004
  • Feb 23, 2004
The ones I have are sheets of real aluminum that look like they have to br glued in. I see about having to grind down where it says Mustang. So I guess my next question what if any modification do i have to do to get a 67 dash trim to fit my 68.
chepsk8
2,203
Easton, PA
Feb 23, 2004
  • Feb 23, 2004
I think all the panels are different. The Plastic bases are shallow, so the Aluminum panels can be glued in so the final thickness is the same as the regular dash. It's a great update, makes the 67 Dash better! Also, 67 guage layout is a bit different, but same shape.
kidtaurus
221
Athens, Ga.
Feb 25, 2004
  • Feb 25, 2004
I am going to forgo this project so if anyone wants to buy the trim I bought PM with an offer. I'll snap some pics later fpr those interested in it.
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Feb 25, 2004
#10
  • Feb 25, 2004
  • #10
Ya know, while I'm glad you aren't going to butcher the 68' set up to accomodate the 67' trim, there is one other alternative if you really had your heart set on it. There could be a 67' owner out there who actually would have prefered the woodgrain option and be in the opposite situation as you. If you were so lucky, you might be able to arrange a parts swap. The units are easily interchangable, just not the trims.
T
Need help locating 67 dash horn wire
  • THS70
  • Nov 21, 2025
1965 - 1973 Classic Mustangs -General/Talk- Dec 5, 2025
THS70
T
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
what would you do? sell the project and buy completed or finish project?
  • STANG32
  • Feb 8, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 16, 2025
rusty428cj
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
