67 Deluxe Door Courtesy Lamp Harness
Bullitt
Packin' Heat
2,743
Houston, TX
I've found some online at the exorbitant price of $32+ each.
My lovely body shop clipped these and then threw them away when they had the doors off the car to paint. I don't have any issue doing the wiring, but I'm at a loss as to where to find similar grommets.
Just need the door lights, don't really care about the speakers.
Any help?
Thanks!
if you're talking about the door/pillar wire pass through grommets and even better version is to rob some off a jeep cherokee (XJ 80's or 90's) the holes are the same size and they are actually identical to what ford used on the 71-73 stangs with the bellows type rubber tubing style. if you want the stock style grommets probably any 60's or early 70's ford will have the same type. the advantage of the bellows type pass through is you can larger speaker cables and you'll have more room for other wiring like power windows and locks or whatever as well. :nice:
