67 Stang + big block radiator + 5.0 serpentine water pump
dcstang67
127
I am in the process of installing a big block radiator into my 67 Mustang. I have the drivers side inlet on the water pump and am trying to figure out what to do for a lower radiator hose. Has anyone figured this one out yet? What hose can I use for this setup?
Same issue here...thinking about just going with one of those chrome metal kits. I have them on my show truck with a custom rad. You just bend them into whatever shap you need them.
Does anyone know if the 1970s hose goes over and is long enough to reach radiators with drivers side inlets?
I went to my local Consumer Auto Parts and they had hoses for a 1970 and 1971, which are different. The 71 is like the picture above, but the 70 seems to be the right size and shape. I am going down in the garage as soon as finish my late lunch to try it out. I will keep everyone posted.
P.S. That kit from Mustangs Plus is for a serpentine conversion with a small block radiator that has the outlet on the passenger side. The big block radiator has the outlet on the drivers side.
