If you had drums up front, you can't correctly use the same master. You can use the mid 90's m/c, but its got to be around the same bore size, smaller will make the brakes touchier.
A drum circuit has a residual pressure valve in the master under the brass insert the fitting seats on. It’s just a small rubber check valve with a small spring.
Your best bet, if you have drums in back is to get the disc/drum m/c for your ‘67. It’ll bolt right up. You do need a metering device of some type weather it be adjustable (not my favorite) or just the correct proportion valve set-up for any car (Granada is a good choice) about the same weight as yours.
