68 overheats. Why???
  • Thread starter Thread starter zwoman
  • Start date Start date Jun 8, 2009
Z
zwoman
12
  • Jun 8, 2009
My 68 has had an intermittent problem with overheating. The radiator was replaced, the water pump was replaced, and I can't tell you how many thermostats I have gone through.still I can't trust that the gauge won't peg at the most in-opportune time. Any suggestions?
G
GDTrumbo
199
Nashville, TN
Jun 8, 2009
  • Jun 8, 2009
First, is it really getting hot? or is the gauge messing with your head?
I used to have a '66 Coupe so 2 things come to mind. Check/replace the temp sending unit.
The second thing is a small silver instrument panel regulator that is mounted on the rear of the gauge cluster. It's about an 1" long and 3/8" wide. It just simply unplugs. If this little regulator is bad it will give you weird readings on various gauges in the panel.
Thats a couple things to check anyway. A good shop manual on this car will be indespensible.
Good Luck, GT
rbohm
6,698
550
204
tucson,az
Jun 8, 2009
  • Jun 8, 2009
i would first put a good mechanical gauge on first and see if it is really running hot. as stated the IVR could be going bad, or your factory gauge might be out of whack. next time you see the temp going up, check the oil pressure gauge and the fuel gauge as well and see if they are going in the opposite direction. my 66 had an IVR malfunction years ago, the temp gauge would peg at the top, and the oil pressure gauge would peg at the bottom. they would return to the proper reading after a few seconds though, but once i changed the IVR that just stopped.
Z
zwoman
12
  • Jun 8, 2009
Thanks for the input. Yes it is definitely getting hot....boiling out of the overflow. I will check the IVR though. Sounds like something to check out.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jun 8, 2009
  • Jun 8, 2009
A mechanical temp gauge is definately the way to go when troubleshooting this kind of thing. Do you have an overflow bottle or is it just bubbling over and then you have to refill the raditator later ?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jun 8, 2009
  • Jun 8, 2009
OK, good, with what type? 2-row? 3-row? 20"? 24"?
Do you have a fan shroud? What type fan?
Surprisingly, this usually has no effect on cooling.
You should be using a genuine Ford 190° unit.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jun 8, 2009
  • Jun 8, 2009
on my 68 the fan was too far away from the radiator to be effective. It should be within about one inch from the radiator.
2+2GT
3,333
10
79
Jun 8, 2009
  • Jun 8, 2009
Unless you have a fan shroud, then the fan tips should be centered in the opening.
A
aug0202
  • Jun 13, 2009
have you tried the radiator cap alot of times the springs get weak and fail to pressurize the radiator properly take it to autozone or advanced and they can test the cap for you for free
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
