69 302 Boss block
  • Thread starter Thread starter TOM B
  • Start date Start date Dec 18, 2006
First Prev 2 of 2
D
D.Hearne
11,730
south louisiana
Dec 21, 2006
#21
  • Dec 21, 2006
  • #21
Eyeless_Seven said:
Heck, see if it is still available I will give you 400.00 and pay for the shipping and crating. Make sure it has 4 bolt main caps and screw in freeze plugs.
ONLY $400?? I can tell from your posts here that you've got a LOT to learn. For starters, 4 bolt mains doesn't make it the best or strongest 302 block made. Any of the aftermarket blocks will top it in terms of strength. Plus an aftermarket block gives you more room (bore thickness) for more cubes.
D
D.Hearne
11,730
south louisiana
Dec 21, 2006
#22
  • Dec 21, 2006
  • #22
TOM B said:
OK, I took apart my supercharged 347 last week and found some deep scatches in the cylinder bores, dont know what happend yet as I didnt take the pistons out yet, block is 030 over now. Edelbrock RPM heads look real good.
I have a 302 Boss block in the basement and am thinking of using it, dont have $2000 for a new block, What do you guys think.
P.S. Im 47 now and probably not going to find a 302 boss car to put it in.
How many scratches are we talking about? If it's just a couple, tear the engine down, re-ring it (bet you busted a few rings) inspect the pistons to make sure the ring lands aren't also broken, hone the bores to clean em up a bit, then reassemble it. Or if you want the roller block route, get one locally, these are a dime a dozen, no need to spend $500 for a new block. The block I used in my 331 build, I bought from a local machine shop for $100, that included the crank, rods and new pistons.
D
D.Hearne
11,730
south louisiana
Dec 21, 2006
#23
  • Dec 21, 2006
  • #23
And Ebay the Boss block. Give it a good home.
First Prev 2 of 2
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
1970 Boss block
  • Sparky714
  • Dec 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 7, 2024
FastDriver
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Engine 302 production block selection
  • FastDriver
  • May 19, 2024
  • 2 3
8K
Fox 5.0 Mustang Tech Jul 1, 2025
FastDriver
