Engine 69 351w Blower Motor
Good day to all Ford Lovers. I'm in a bind. I've seen forums before regarding 351W Blower builds. Well I'm in the same boat. I'm looking to build a 69 351W Blower motor. Won't take "NO" for an answer because I know it can be done. I've invested to much already to turn back now. Who can help me out. Spoke with Dyer's & they said I can put on an 8-71? How true is this? I've had the motor stroked already to a 427? I hope. Machine shop went bankrupt & I just got motor out in time but no paper work to confirm. I know they installed new crank and pistons but don't know what kind. I need a cam but don't know what to get. I'm not a mechanic would appreciate everyone's input. I already have Aluminum heads but not installed yet. I'm still researching all my options sending out e-mails for Blower applications so I know its possible but car is not intended for race. Just a Sunday cruise. So lets open up the floor to who can help me out.
B&M did a blower for the SBF but it required adapter plates to fit the 351W. good little 8-10psi blower. What cylinder heads do you have. As far as the shortblock, it would be good to have another competent machine shop double check the work done by the now out of business shop, just to be sure that you are not throwing good money after bad.
If I were in your situation I would want to know what compression the engine is set up for. Then I would also need to know when the intake valve closes and I would calculate dynamic compression. Then I would determine whether the dynamic compression is good for the fuel I plan to run. Also, if it were me I would want to know exactly what rods, crank and pistons are in the engine. Some pistons are built to withstand boost and others are not. I'm not sure whether you want an 8-71 or 6-71 - the 8-71 will make more boost and you might need that big of a blower to get the 8-10 lbs you are currently looking for. I would recommend discussing with the manufacturer of the blower. I think you should make sure you know all the details of the build before calling because they will want details in order to give you the correct advice. Make sure you have a strong crank that will handle the load from turning the blower pulley.
Maybe you know all this and have it all worked out, but the tone of your post seems like you are unsure.
The rest of my advice would be all around making sure the structure of your car is stiff enough to withstand the power you are going to make. You didn't say what car you're putting it in, but a blown 427 small block will put a hurting on just about any Ford unibody structure. You will want the doors to continue fitting the body and closing properly! Don't forget the drivetrain and suspension, either!
Good luck!
