'69 Heater Blower replacement
  • Thread starter Thread starter Ro-Longo
  • Start date Start date Aug 12, 2008
R
Ro-Longo
  • Aug 12, 2008
Ok, call me an idiot.
But it looks like the entire heater box needs to be removed so I can replace the heater blower motor. Am I correct or is there an easy way to do it.
oh yea, no A/C on this car.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Aug 13, 2008
  • Aug 13, 2008
yes the ENTIRE heater case... i dont remember if the dash needs to come out or not.... are you sure its the blower motor???
what did you do to test the motor itself?
yeloxr7
429
  • Aug 13, 2008
The heater case does need to come out to replace the blower motor. The bolt holding the dash to the cowl on the passenger side and the brace below the glove box need to be removed so the lower right portion of the dash can be pulled out. The dash pad needs to be removed as well. All this is detailed in the factory shop manual.
While you have the blower case out, it is probably a good idea to replace the heater core and the foam seals on the case and air-control flaps and doors.
J
Electrical Engine harness replacement
  • Jarhead67
  • Aug 23, 2025
Fox 5.0 Mustang Tech Aug 27, 2025
Jarhead67
J
M
  • mnky99
  • Sep 5, 2025
mnky99
M
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
