Have any of you put a 69 gas tank in your 67 or 68? I was told that they bolt right in, which they do, but what do you have to do to make a connection between the filler tube and the tank inlet? There is a very big offset. I cut the tube about 2" shorter and that doesn't help.
The problem is that the tank inlet sits much further to the rear of the car, and to make a connection even with a flex hose would create an 'S' shape that I'm sure would affect pumping the gas in beyond a trickle.
Any help is appreciated!
