7.5 gears?
  • Thread starter Thread starter fly4spd
  • Start date Start date Jun 22, 2004
fly4spd
118
Las Vegas & Reno
Jun 22, 2004
  • Jun 22, 2004
do they make aftermarket gears for the 7.5" rear end. if so where can i get them?
Thanks
-aj
cenok is family
1,409
69
79
Norman, Ok
Jun 22, 2004
  • Jun 22, 2004
im not sure about the older 5.0's but on the newer 4cyl's with 7.5's, standards had 3.73's and auto's had 4.10's. so just find a newer four banger and pull the rearend. You probably already knew that but, yeah. adios.
88stangmangt
2,332
Stafford,VA
Jun 22, 2004
  • Jun 22, 2004
check summit.....................
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jun 22, 2004
  • Jun 22, 2004
Are you sure? Isn't it 3:73 for auto and 3:43 (or something) for manual? But yeah just get some gears from an auto 4 banger but I'd suggest a 8.8 right away while playing in that area...
fly4spd
118
Las Vegas & Reno
Jun 22, 2004
  • Jun 22, 2004
ya i was looking just for gears not an entire rear end... I'm trying to figure out whether i should put gears in, probally like 3.55s, or just save the money and go to the 8.8.
fly4spd
118
Las Vegas & Reno
Jun 22, 2004
  • Jun 22, 2004
well. i just found some at summit they have 3.45 and 3.73s for the 7.5 inch. i'm searching the boards right now on which to go to. the thing that i'm thinking about is that i go to school 450 miles away and make the trip 6 or 7 times a year. any thoughts?
Euphoric306
905
  • Jun 22, 2004
get an 8.8 swap, theyll last longer. i learned this turbo coupe thing from someone on stangnet, sorry i cant give credit personally, but go to a junkyard and find a ford turbo coupe, it had an 8.8 rear end with 3.55's (stick) or 3.73's (auto) and while your in there you can grab the rear axles and disc brakes for a full rear end upgrade, all parts for easily under 350 bucks.
85GTlover
704
  • Jun 22, 2004
The newer and older 4cyl have better gears but no way do the newer auto's have 4.10's.....keep dreaming, maybe 3.53's or what the other guy said but in the 4's......no way, but they do have better gears than there bigger brothers. Dumb, I think, but true. I have always been told to swap and don't waste money on the 7.5" save for the 8.8, much stronger rearend. Why risk it? It is an easy swap but gear swaps are much harder.
D
What's it Worth? Considering Selling '82 Fairmont Futura Body Shell
  • DonMay63
  • Apr 5, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Apr 5, 2026
DonMay63
D
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
