71 Mach 1 front end seems to be higher than ack end
JJHstang
5 Year Member
Sep 12, 2018
222
14
18
Fort Worth, TX
When I look at my 71 Mach 1 it looks like the front end is higher than the back end. I measured from the bottom of the body to the ground behind the front tire and in front of the back tire. The measurements are the same. Is there a better way to tell or is it an illusion?
it is an illusion. however if you dont like the look you can cut off half a coil from each front spring and that will lower the front enough to make it look level, or slightly lower.
