73 Manual trans
  • Thread starter Thread starter rustybutterknif
  • Start date Start date Aug 11, 2006
rustybutterknif
Louisville, KY
Aug 11, 2006
  • Aug 11, 2006
What manual trans was used origionally in 73 mustangs with the 351-cleveland 4v engine. I was wanting to ditch my FMX and I don't like automatics. Especially the heavy C6. I don't want to deviate too much from what might have been optional equipment at the time, and am kinda looking at it as a sort of bolt up solution. Also how would I ID such a transmission.
Thanks in advance.
68RCodeConv
345
Houston, TX
Aug 11, 2006
  • Aug 11, 2006
There was the standard 3-speed and the optional toploader 4-speed. Probably all the 4-speeds were wide ratio - I don't think the close ratio was available any more in 73. If I were starting from scratch like you are, I would just go ahead and put a 5-speed in it. That way you can run steeper rear gears (which 4V Clevelands need) and still cruise on the highway.
rustybutterknif
Louisville, KY
Aug 11, 2006
  • Aug 11, 2006
The 5 speed your speaking of, is that the same one from the 5.0 cars? What type of linkages does that one use? Just trying to get an Idea of wht I'm in for here. Also how do I get rid of these freaking links to dumb stuff within the posts?
G
Gud T.B. Blown
583
Aug 12, 2006
  • Aug 12, 2006
If your cleveland is stock the T-5 is an acceptable option. However, if your Cleveland is built and you plan on driving hard you'll want to think twice about using a T5 (max torque rating is 300lbs.) and think about a Tremec TKO. It's a bit pricier but it was engineered to handle the amount of torque a healthy Cleveland produces.
A true bolt in will be a toploader. I did the exact same conversion you're thinking of 2 years ago. The hardest part is finding the clutch linkage and pedals.
C
Bored with my 73
  • Curtis Harper
  • Apr 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 23, 2026
RaggedGT
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
