what are your plans for the car that a 75mm t/b is even necessary?xbajbusx said:its stock for now im upgrading slowly ,
Green 94 5.0 said:what are your plans for the car that a 75mm t/b is even necessary?
94gts said:like they said its pointless at this moment in time. the opening behind the tb on the stock intake manifold is not big enough to accept the larger diameter throttle body. it would need to be taken off the car and opened up with a dremel or something (to 75mm). the results would be miniscule and not worth the cost/effort.
He hit the nail right on the head! I wouldn't go any bigger than a 65mm TB.Grn92LX said:Yes it will bolt on. But it wont match up with the stock adapter as thats 60mm. So by doing this you create a 15mm wall for air to hit and cause a disturbance in flow.
xbajbusx said:i got off road h pipe on the car pullies ,3.73,flowmasters,cold intake with air ram kit ,my planes where to get the 75 mm tb and then get the intake and the elbo ,i can get 75mm for like 100 bucks from friend of mine so i was just think for now to get it and put it on
