Carb tuRBO 2.3L was rated IIRC at 145hp from the factory, you can get a gillis boost gauge and run boost to 11 lbs and it should be pulling close to 175hp.
You will have to see if oyur crossunder pipe will clear your K-member. From tehre stock 2.3L turbo mods all apply. Bigger cam, 3" downpipe, 3" exhaust, turbo cam, ported head, etc. Also you will need to bump the carb jets a wee bit to support the extra boost.
I am thinking if you keep it mild 190hp isnt unreal and if you get crazy with it 250hp is possible. If at all possible you need to port exhaust manifold and get exhaust manifold, crossunder pipe, and exhaust side of turbo jet hot coated. One of the guys who has a 79 turbo had a 3" crossunderpipe made and he said that alone almost eliminated turbo lag. If you jet hot coat the crossunderpipe and exhaust manifold you keep the heat in the exhaust and that boosts the throttle response.
