8.8 clutch pack rebuild
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Ok I have Ford's rebuild kit. It has all the schims and clutch's I need. Now the problem or question I have is about the clutch gauge assemble tool they tell you to use. They say for High Torque 8.8's you need a 1.3 inch assemble and for non high torque (which I think the mustangs have because they do not have the 7/8 pinion shaft they have the 3/4 inch one) is a 1.250.
1) How exactly do I mesure this without this tool? Just stack them and measure with vernier? Is there some load that has put on them to measure?
2) I have heard guys talk about installing an extra clutch in them. Is this a good idea?
Hmmmm... you've lost me on the measuring tool (shoot me). Presoak the clutches (in friction modifier) and load them clutch, spacer, clutch, spacer, etc... all the way across. Use the best of your old clutches as your extra. Pack em all in there and replace the S-spring. Don't forget to put friction modifier in the diff.
Almost looks like the instructions say to use 2 clutchs to every 1 spacer. Does this seem right?
So it is a good idea to install more clutch's to tighten it up? Or just use a bigger schim on the end.
Yeah... lol. 90W gear oil stinks to high heaven. Don't get it on your clothes and wear latex gloves if you can. Don't get the stuff in your eyes either. I'm not an avid wearer of safety-glasses but rear end work has me wearing them every time.
Basically when you add the extra clutch you remove one of the steels. I think the factory stacking is steel-clutch-steel-clutch-steel-clutch-steel. The alternate method is clutch-steel-clutch-steel-clutch-steel-clutch. plus whatever shims you need. I didn't use a clutch gauge assembly tool. I ended up not being able to use any shims cause I couldn't get the spider gears back in with even one of the thinnest shims in on either side. Basically getting it back together was a try to assemble it with a certain shim set up and if it wouldn't go back together move down to the next smallest shim set up until the spider gears would roll back in. Don't know if that is the approved method but it worked for me.
The factory set up is Shim, Friction, Steel, Steel, Friction, Steel, Steel, Friction, Side Gear
The modded is Shim, Friction, Steel, Friction, Steel, Friction, Steel, Friction, Side Gear.
Or atleast this is what I have read. Since the modded has one less thing to put in I would guess that I am going to have to use a larger shim.
Thats the right set up that you have there. Its been awhile since I messed with mine.
Actually you will end up using a smaller shim, in my case no shim, since you are replacing on of the steels with a thicker friction disc. When I did mine even with the smallest shim in I couldn't roll the spider gears and side gears back in. It was just too tight. With no shims it went together and I haven't had any probs with it.
I guess I'm going to have to roll both spider gears back in at the same time.
Ok so I have both spider gears in but there seems to be a little bit of movement between the spider gears. Is this normal or should I get them to fit really tightly. I could schim one side. That being said It looks like it will be near impossible at this point to get the s spring in. it is very tight for it right now.
