Would this be what I need to rebuild a burnt rear end? By rebuild, I mean everything in side the "pumpkin" was burned up. The only thing salvagable are the axles and housing. I figured I'd upgrade the LSD and axles though.
Ring gear & pinion
Eaton Posi Limited Slip 8.8in 31 Spline Differential
Moser 31 Spline Mustang Axles for 8.8in Rear w/ Studs (99-04 GT, Bullitt, & Mach 1) --- what about ABS?
Motive bearing kit
Front & Rear Pinion Bearing
Pinion Seal
Carrier Bearings
Carrier Shims
Differential Bearings
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Gear Marking Compound
Loctite
Ring gear & pinion
Motive bearing kit
Pinion Seal
Carrier Bearings
Carrier Shims
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Loctite
you have everything else just need the bearing master kit, along with axle seals
