8.8 Rebuild Question....
  • Thread starter Thread starter crumbie50
  • Start date Start date Jun 12, 2007
C
crumbie50
  • Jun 12, 2007
My bro-in-law and I recently rebuilt the stock 28 spline differential in my '93 coupe. We re-shimmed the clutch pack so that the spider gears went back in extremely tight. Last night, got the differential installed in the rear and slid my two new moser axles in. Put the c clips in, pulled the axles out, and went to put the pin in. Well, I guess since we re-shimmed the spider gears, it doesn't allow the axles to move outward enough to give enough clearance so the pin will go through. I've heard of quite a few folks rebuilding the rear this way and was just wondering if anyone else has come across this problem before.....
Thanks in advance!
JChalfan
551
Bellevue, WA
Jun 12, 2007
  • Jun 12, 2007
I had the exact same problem when I tried to setup my trac-loc tighter. I ended up just setting it up at factory specs.
I've definitely seen some posts on here that talk about this. Try a search for something like "posi shim" if you haven't already.
Good luck.
Jeff
C
crumbie50
  • Jun 12, 2007
Good luck.
Jeff
Thanks for the advice Jeff! I've heard of local guys doing this and I know it's been done before, just don't know how they managed to get it done.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
