Ok, first off I did a search and didn't find what I needed.
I have read that the 8.8 from the pre 99 cars are narrower than the 99-04 8.8's. Can I swap in an 8.8 from a 94/95 GT into my 2000 V6 without worrying about tire rub or other clearance problems ?
03ghoststang
Well-Known Member
i dont remember on how short the axle tubes are on the 94-98 compared to the 99+ but i believe that its was about 5/16" on each end but not too sure on that
hotrodnut
I'm not sure of how much narrower either but I've heard an inch?Rusty67 said:Ok, first off I did a search and didn't find what I needed.
One other thing is the mounting holes for the lower control arms on the earlier versions are too small for the bolts of the newer version on the GT's and Mach's and will need to be drilled out to fit. I'm not sure if that is the case on your Mustang though.
I don't think the bolt hole size will be an issue for me, I'm geting a free set of lakewood rear control arms with the rear end.
As for the rims, right now they are stock but I'm going to be using the 17x8 2001 Bullitt rims. We already have the rims but are waiting until the ruber on those 16's is shot.
elite130
It will fit. The 99-04 axles are 1.5" (or 3/4" on each side) wider than the 94-98's. They will fit just fine, except for the bolt holes as you all have already discussed. I have heard many many people do this, both put 99-04 on a 94-98 and visa-versa.
It will work, but picture your wheels now sucked in 3/4" each side.
I hate how sucked in my bullitts look now with the stock 99+ rear end, i can't imagine running a narrower 94-98 rear. I was considering 1" spacers just to push them out more.
- Replies
- 2
- Views
- 613
- Replies
- 15
- Views
- 625
- Replies
- 41
- Views
- 1K
- Replies
- 1
- Views
- 184
