8 rib AC delete?
This is what I used on my 2000, which was just the stock 6 rib design but the only difference would be finding an 8 rib idler/tensioner pulley and modifing a tensioner arm to work like this.
2v Belt Diagram & w/AC Delete - Modular Revolution Forums
If you wanted to keep the FRPP delete I'm sure there are alternate 8 rib pulleys you could use.
Bill
I can'I see the pic on the other site. If you are using a ribbed pulley on the tensioner. I can't do that because of the SC
if the AC delete has a 17mm mounting boss, then you could put most any idler there you wanted, including 8 rib pullies. Goodyear and Gates both have hundreds of different pulleys that fit a 17mm mounting boss.
How can I find the size of the mounting boss on the frpp kit? The last dufus I called there had know idea that there was even a need for an 8 rib AC delete.
On the 5.0s Ford had a bracket to move the PS pump up to the AC location and then you just run a shorter belt. Anything like that out there for the 4.6 yet ?
No there isn't. The AC and PS pump mount directly to the block/timing cover and have different bolt patterns. I'm sure something could be machined but it would be fairly involved and the amount of work to re-do the PS lines to reach to the other side of the engine would be pretty expensive and a pain in the ass.
Bill
