Been looking at an '84 5.0 LX hatch with CFI that I might be obtaining soon, but thought I'd ask to know what I'm getting into before I wind up getting it and finding out I can't do jack with it. I know the basics involved in what's needed to actually do the conversion - Duraspark ignition swap, delete the frame fuel pump, AOD linkage to the carb, etc. - but as far as being able to pass smog ... if I put the CFI-to-carb swap together with 50-state legal bits (intake and carb, mainly), and since they did still have carb'ed 5.0's in '84, would I still be able to pass Arizona smog testing?
Visually, I don't think they'd have a gripe as long as the EGR and smog pump connections are all there, but will the actual emissions be worse than with the CFI setup?
Just the same ... would it even be worth messing with swapping from CFI to carb? ... Or can decent power (around 200 rwhp) still be made on a CFI setup?
I know that swapping to EFI would be the obvious better upgrade (especially just dropping in a whole '87-'93 long block), but it's a LOT more involved (and expensive) than swapping to a carbed deal. Not looking to crank out 300+ horses or anything wild, just something simple and cheap to put together, running well, and not having any smog inspection issues.
Or at least something designed aftermarket to fit those older applications.
