85 distributor and pump rod issue...HELP!
  • Thread starter Thread starter MrKwik
  • Start date Start date Nov 14, 2004
MrKwik
1,008
Kansas City, Kansas
Nov 14, 2004
  • Nov 14, 2004
I converted my 89 EFI motor to carb and used the stock pump drive rod. I got an 85 distributor and the shaft below the gear is shorter than the stock one. The old one was 1.5" and the 85 is 1". With the stock rod it only goes 5/16" into the distributor shaft. That doesnt seem like very much and Im concerned. Im trying to figure out if this is how the 85's were and its fine or if I got the wrong distributor or what. I thought that maybe they use a longer rod in 85 but I have an extra 85 motor and lookong down in the hole it doesnt look like it extends any further up than the one in the 89. I need to know for sure what Im looking at here, if I need to pull the motor back out and change the rod or what. If somebody has an 85 distributor tht they could look at and see if it is the same length so that I know I got the right one that would be great. Here is a picture with the new one on the left so you can see the difference.
MrKwik
1,008
Kansas City, Kansas
Nov 14, 2004
  • Nov 14, 2004
shameless bump...
anybody got any insight on this?
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
