85 mph brick wall
  • Thread starter Thread starter 67coupestang
  • Start date Start date Apr 11, 2004
First Prev 2 of 2
67coupestang
509
#21
  • Apr 13, 2004
  • #21
wow didnt mean to start such a riot! but anyway. more specifics... The car WILL do more than 85, but not in 5th gear, Im pretty sure its the 750 just bogging out, thats what it sounds like, the motor is a recent rebuild from a late 70's t-bird, so its healty, not performance built (cam and heads). at high rpms and just off the line without wind resistance i have no complaints torguey as hell!! I guess i pretty much figured the problem just wanted to rant...
skywalker
733
Pensacola, FL
Apr 13, 2004
#22
  • Apr 13, 2004
  • #22
750 cfm could do that if you motor isn't built for it...i have a 289 and the only majorengine change i have is intake...i have a edelbrock 650cfm 4bbl, You might want to change out that carb and see what happens.
dodgestang
1,360
Cecil County, MD
Apr 13, 2004
#23
  • Apr 13, 2004
  • #23
Wow....I can't beleive this post took a gearing turn. It is unlikely and unless you are pulling like 1000 RPM or less in OD at 85....its not a gearing problem. If you have ever had your setup dynoed you would have a power curve and you would be able to confirm on the chart that you are still in the car's power band when you are at speed in OD (which you are most likely just at the bottom of the power band)
With that said....silly questions but....
1. Confirm you are really getting a full throw on the throttle. With car off look down carb throat and have some one IN THE CAR floor it with the pedal so you can visually inspect the primaries are opening all the way.
2. Are your secondaries opening? I just took a 770 VS of my mustang that sometimes the secondaries would stick and not open. The car would essentially just stop at 3500 RPM and not be able to go anymore (because it wasn't getting enough gas). I switched to a new carb and that problem was fixed. Along those lines...have you put in a new fuel filter to make sure it isn't a clogging issue?
3. Have you confirmed there is no vacuum leak? If you have a small vacuum leak with the RPMS you pull in OD you might not have enough vacuum to actually open the secondaries (pulling at straws here now ) while unlikely it is plausible.
And for the record....my CLEVELAND stroker with my .68 OD has no problem running it up from 1300 RPM to 4500 RPM in OD in about 2 heartbeats......but I generally keep it out of OD until I can keep it above 2,000 RPM consistantly.....to put it another way, I only use OD when I am on the freeway or a very long stretch of country road.
67coupestang
509
#24
  • Apr 13, 2004
  • #24
yup a full sweep there.
I think they are opening, i can definately hear a change in the exhaust when i punch it. it will rev fine in any other gear. oh and wouldn't a fuel filter clog be more evident at high rpms?? but yes a new filter is on the list...
no leaks heard...
First Prev 2 of 2
C
Suggestions for rear diff gears - 1969 Mach 351W 4v
  • cfauvel
  • Apr 8, 2024
2K
Classic Mustang Specific Tech Jun 27, 2024
cfauvel
C
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Progress Thread Black Beauty: '85 GT T-Top: Winter Is Coming
  • LiquidStangs
  • Jul 30, 2019
  • 2 3
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2019
LiquidStangs
J
Driveline Vibration
  • jeffsqartan
  • Aug 24, 2017
6K
Fox 5.0 Mustang Tech Aug 31, 2017
jeffsqartan
J
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
