SOLD 85 Mustang Race Car "roller" Atlanta Ga
Parts Atlanta
1985 Mustang Track Car, not built to any specific class rules,
Located near Atlanta GA
Built 5.0 Engine is out of car and needs a full rebuild or replacement
$6000 OBO..."cash talks"
Car sold with Bill of Sale only, no title as the car is NOT STREETABLE! This is a full stripped out caged race car
Engine is out of car and disassembled but is included in the purchase price. The engine can be rebuilt, it is not "Blowed Up" but will need a full rebuild. (tranny & drive shaft in the car)
Some parts may be sold as time goes forward...I will update the list if/when anything changes
An RPM open Trailer All steel with wood deck is available @ $3000 (price is firm) This is a brand new trailer, only used 3 times...
No requirement to buy Car & Trailer as a package.
Car/Trailer located in Atlanta and is available for inspection with 24 hours notice
Engine (NEED REBUILD AND OUT OF CAR)
5.0 302ci 300 RWHP
Forged Pistons & Rods
Machined/Polished Heads with upgraded Valves, Springs, & Rocker Arms
Trickflow Camshaft
Clevite Bearings
New HEI Summit Racing Distributor & Wires
Shorty Headers - Fiberglass Wrapped
New Water Pump
3 Core Ford Racing Aluminum Radiator
New Starter
Facet High-Flow Electric Fuel Pump
Insulated Fuel Lines
Maximum Motorsports Solid Engine Mounts w/ARP Bolts
Ford Racing Dip Stick
New Edlebrock Valve Covers
New Air Cleaner
Transmission (Recently rebuilt with one track event)
T-5 Transmission non world class with Road Racing Fifth Gear
New King Cobra Clutch
New Lightweight Flywheel
Prothane Transmission Mount
Steeda Billet Short Throw Shifter
Steeda Adjustable Clutch Cable, Billet Quadrant, FW Adjuster
Maximum Motorsports Clutch Pedal Height Adjuster
7.5" Rear end with 2.73 Gears
Upgraded 7.5" Aluminum Differential Cover W/CAP Supports
Custom Aluminum Driveshaft
Braking
5 Lug Conversion
Cobra Calipers
Hawk DTC-60 Pads
New Rotors
Brake Cooling Ducts
Chassis
Fully Enclosed Cage with NASCAR Style Door Bars & Roof Halo
“In The Floor” Subframe Connectors
Koni Shocks
BBK Springs
Maximum Motorsports Caster/Camber Plates set to -3 Degrees of Camber
Maximum Motorsports Panhard Bar
Maximum Motorsports Control Arms
New Energy Suspension front swaybar bushings
Interior
Lexan Polycarbonate Windows
Custom Aluminum Dash
OMP HTE_ Seat
OMP Seat Sliders
New Schroth Profi 6pt Harness
Fire Extinguisher
Detachable OMP WRC Steering Wheel
5 Pane Racing Mirror
Kill Switch
Longacre Helmet Hook
QuickCar Switch Panel (Ignition, Start, Access Etc…)
New Shift Knob
Autometer Ultralight Gauges (Water Temp, Oil Temp, Oil Pressure, Fuel Level, Volts)
Wheels & Tires
17" Cobra R Wheels
Toyo RA1 Proxies
Other
Summit Racing Battery Box
FlowMaster American Thunder Exhaust 2.5"
BBK X-Pipe
AMP Transponder
Sealed Lightweight Battery Box
Heal and Toe extenstion
Oil filter adapter for Sender
New Fuel Sender
Removable Hood
New Cowel
