A few ways to do it.
#1 is to buy a 1989 Cluster which is a direct drop in. They switched to 140MPH halfway through the year, so only some have it. That makes it a very rare cluster so it tends to be pricey.
90-93 clusters need to be rewired to work, so leave this as last option.
You can also purchase an 89-93 140MPH speedo alone, and install it in your cluster. You just remove the needle, unscrew the mechanisn from the clear plastic support and swap it with your 85MPH speedo.
Then you just need a face. Go with an aftermarket overly, or try and retrofit the 90-93 140MPH face onto your older cluster.
When you reinstall the needle, take note to a small tick mark BELOW the 0MPH line. Remove the needle stop. With the gauge installed at proper orientation, the needle should point at this tick mark and NOT 0MPH. That way when you reinstall the needle stop, there's a little downward pressure on the stop.
