86 5.0 Wiring Help? (Coil)
Hisser
Currently - I'm doing a 68 Shelby Convertible tribute.
Have a 5.0 EFI (speed density) motor from an 86 Fox mounted, ready to go.
Problem - A guy gave me a modified wiringness ( based on painless supposedly) that he integrated into a single main harness. Well, the FPR doesn't work and injectors wont open. He says the 3 computers I have are bad. Hard to believe
So I now have my original 86 main harness back. There is no coil wiring on this harness? I beleive the coil wiring was a part of the another harness I don't have. I"m trying to figure out how to run separate wiring (if possible) or splice in the coil lines into this original harness. I do have the fuseable link wiring in both harnesses so I thought I could cut the coil wires from the bad harness and splice them into the original. However I cannot find the other wire (ground? - the hot line is green w red stripe) in the original wiring harness? Can I just ground it somewhere? I figure not. I'm at a loss how to proceed. I
Thanks for any input.
Hisser
86 5.0 Mustang ECC wiring diagram with ignition
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
1986 Mustang 5.0 1986 EEC/ ECM. EFI wiring schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-86-Mustang-ECC-EFI.gif
1986 Mustang 5.0 1986 Lighting Diagram schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-86-Lighting-Diagram.gif
1986 Mustang 5.0 1986 Body Diagram schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-86-Body-Diagram.gif
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Hey jrichker,
Man, what a resource!! Thanks for the tip. This should fix me up quick. By the way, I'm in Rome, GA. Appreciate your hospitality and assitance my GA friend.
Hope to get this machine rolling sometime soon.
Hisser
