86 engine harness in a 87-93?
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Can it be done? My friend wants a stang bad.. but his parents wont buy him one so he wants me to help em get one which he will buy al lthe parts and car. 91 hatchback 4 banger.. straight and clean and a 96 GT40 motor which i have the mustang parts to change it over correctly I.E. cam, distributor.. And the big part is the harness. I have just a extra harness and computer from a 86 GT we have. I doubt he cares if air bag or anything works but as long as the car runs and drives safely then its alright. Is there a way i can make it work?
It is purely a function of how good you are in the automotive electrical department. If you have very good electrical skills, can read diagrams and troubleshoot electrical problems without outside assistance, then it is doable. If you are not good in these areas, it isn't doable.
Like I said, you will be pretty much on your own. You will need diagrams of both the current harness and the target vehicle. You will need to identify each wire in the harness that does not directly connect to the computer. You will need to identify each wire in the vehicle harness that would normally connect to the computer harness. Once you have identified both sets of wires, write them down and figure how to connect like functions, headlight to headlight, turn signal to turn signal, etc.
