86 notch brake line replacement
  • Thread starter Thread starter x1986chpstang
  • Start date Start date Mar 9, 2011
x1986chpstang
  • Mar 9, 2011
hello all! i have a 1986 mustang coupe with a 5lug convertion and i want to replace my brake lines with braided!!! so my question is........ do i buy a brake line kit for a sn94-95 becuz i have disc in the back??? becuz i know 79-93 fox bodies only have 3 brake lines and 94-95 had 5?!?!?! ( and i have 5 )
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Mar 10, 2011
  • Mar 10, 2011
The answer to this question depends heavily on which 5-lug setup your car has.
your assumption is correct, because Sn95 use 5 lines...which you have now. However, there are several different setups that the Sn95 kit is not compatible with.
So, do you know exactly what brake setup your car is wearing?
x1986chpstang
  • Mar 10, 2011
No!! I bought the car this way!! Although the guy said it was a svo rear end. And I just found out the the svo's came with rear disc brakes with 5lug.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Mar 10, 2011
  • Mar 10, 2011
Well, you need to be sure because the lines are not compatible woth the sn95 lines...however the rear lines are similar.
Got pics?
x1986chpstang
  • Mar 11, 2011
No but I can take some. I was just thinking about pulling the ones I have off and getting some custom made
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Mar 11, 2011
  • Mar 11, 2011
Well, if they are truely SVO, then you could just get stock Fox lines for the front and axle, and then you'd just need to source out the rear caliper soft lines.
Of course, i would check that the fitting sizes are the same for 86 as 87-93. If they are, there are at least 3 lines that may be simple purchases.
In fact, you may need Fox lines for front and axle, and Sn95 lines for the rear calipers...but you might need adapters/mods to make the rear caliper lines work depending on what the PO did with the rear brake line setup
x1986chpstang
  • Mar 12, 2011
Another question if u don't mind. I have a brand new x3z EEC, do I need anything special to run this on my stang??? I have bbk cold air, 75mm egr, 75mm tb, a cam, far heads, maf sensor, and long tube headers!!!
x1986chpstang
  • Mar 12, 2011
Afr heads!!**
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Mar 12, 2011
  • Mar 12, 2011
That's a 1993 cobra computer....nothing really desirable.
You need 24# injectors and a ford F1SF mass air meter to use it. No other parts will work.
Assuming your car is already a mass air conversion car (you said you had mass air) then an A9L is already a superior computer to use.
x1986chpstang
#10
  • Mar 12, 2011
  • #10
Sweet! Thx. Um I got some pix of those brake lines in the rear and middle rear. I dunno how to post pix on here cuz I'm using my iPhone, but can I get ur email so I can send u these pictures??
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
