So I stumbled upon a post that because of true flat top pistons in an 86 bottom end, E7's may not work?
Im not quite sure if GT-40's will end up on this motor or not, but I was planning on using E7's from a 90 GT if it didnt happen. I do have the stock heads that came off the motor which are E6's correct?
Basically, will E7's, or GT-40x heads have clearance problems with a stock 86 bottom end?
Thanks in advance.
Thanks in advance.
