87 5.0 backfires 1st - 2nd shift high rpm
Jay5_o
82
calgary, canada
Got a problem with backfire under load when shifting from 1st to 2nd 4500+ rpm. sounds like a gunshot going off, and its embarrasing when im raceing.
I got newer rotor ,cap ,spark plugs, wires
what would cause this? leaky injector ? wrong kind of spark splugs ?timing ?
any input would be helpfull to fix this problem
Well the off road h pipe doesnt do you any justice in that feild. It give a spot for extra fuel to burn after it leaves the engine. With no cats you tend to get a little backfire out the tail pipe. a bad injector could do it too.
Chek to be sure you vac line is still connected to the map sensor If you still SD. Make sure your Spout is plugged in also. Just a couple small things to chek.
If you have a timing light, check the timing. I believe that MAP sensor is on the firewall to the right of the upper intake and it has a vacuum line connected to it...check to make sure that it's in tact and not leaking.
Jay5_o said:
"Chek to be sure you vac line is still connected to the map sensor If you still SD"
huh ? explain
On Speed Density mustangs the MAP sensor reads the vacume from the manifold. If the line is off, kinked,leaking, etc it will cause problems. The map sensor is a black box next to the vacume tree its not in the center of fire wall but close to it.
