87 Gt 5.0
Andrew Benz
Hi everyone I'm Andy I recently bought a 87 gt 5.0 spd roller got a motor now I'm looking for a t5 I found a built t5 with stage 3 clutch and a3.35 gear ratio out of a 3.8 v6 will this tranny fit my semi built 302 with the 5.0 bell housing
You'll need to swap the input shaft and bearing retainer out for one from a 90-93 t-5 unit. Then it will bolt into your current fox 5.0 bellhousing.
Later V6's went electronic speedo, but you should be able to tell if you have a mechanical or electronic speedo by looking at it.
